pySerial
Filed under: Addons
Tags: ,
The pySerial module is a Python add-on that provides access to the serial port.
Installation:
  • Having pywin32 is a requirement for using pySerial. Follow these instructions to install pywin32 with Vizard.
  • Go to the pySerial download page and download the latest version of the pySerial installer. The installer should work for all versions of Python.
  • Run the installer. It should automatically detect Vizard's Python installation. If you have multiple Python installations on your computer, make sure you select the Vizard Python installation.
Example:
Open port 0 at "9600,8,N,1", no timeout
import serial
ser = serial.Serial(0) # open first serial port
print ser.portstr       # check which port was really used
ser.write("hello") # write a string
ser.close() # close port
Open named port at "19200,8,N,1", 1s timeout
ser = serial.Serial('/dev/ttyS1', 19200, timeout=1)
x = ser.read() # read one byte
s = ser.read(10) # read up to ten bytes (timeout)
line = ser.readline() # read a 'n' terminated line
ser.close()
For more examples and documentation visit the pySerial page at SourceForge.net
