Connecting Vizard to BIOPAC AcqKnowledge
By Jeff Loomis
BIOPAC provides a large range of monitoring devices for detecting physical or physiological changes over time. The BIOPAC virtual reality platform provides:
Controlled and replicative experimental setups
Manipulation of the environment (and avatars) that would be impossible or prohibitively expensive in the real world
Synchronization of the events from the virtual world with physiological data
Biofeedback data transfer protocol for real-time digital communication, which allows the participant’s physiological feedback to control the VR world
Using physical data with Vizard
Vizard supports interaction with the data provided from these devices using the biopacndt.py module, a Python API for connecting to BIOPAC’s AcqKnowledge software with Network Data Transfer (NDT).
Note: biopacndt.py is included with the NDT license; contact support@biopac.com if needed.
The connection to AcqKnowledge can be made locally or over the network. As long as the Respond to auto-discovery requests option is enabled in AcqKnowledge there is no need to specify a remote machine’s IP address in Vizard.
If you have AcqKnowledge installed, the biopacndt.py file is found in the following location: C:\Program Files\BIOPAC Systems, Inc\AcqKnowledge\Network Data Transfer Examples\Python 2\source Copy and paste the file to the Vizard Python folder: (C:\Program Files\WorldViz\Vizard\python). Placing files in the Vizard Python folder will ensure each Vizard project can load them.
Software setup in AcqKnowledge
Enable the NDT Network Data Transfer protocol in AcqKnowledge in order to stream data to and from Vizard. (NDT is a licensed feature add-on.)
In AcqKnowledge, go to Display > Preferences > Networking.
Select the checkboxes for Enable network data transfer and Respond to auto-recovery requests.
Restart the AcqKnowledge software to activate the Network Data Transfer.
This configuration only needs to be done once.
To see event markers in AcqKnowledge, have the events bar visible
You can also toggle to show the “Event Palette” to see a timeline of events.
Vizard to AcqKnowledge
In the code below, Vizard sends a signal to drop an event marker in AcqKnowledge:
AcqKnowledge to Vizard
In the following code, Vizard prints out the data streaming from AcqKnowledge:
