Voice recognition
Filed under: Addons
Tags:
This article describes how to perform voice recognition in Python using the 3rd party pywin32 library along with the Microsoft Speech SDK.
  • Download and install the pywin32 library.
  • Download and install the Microsoft Speech SDK.
  • Run the makepy script and select the Microsoft Speech Object Library from the list and click OK. The makepy script should be located in your "[Vizard]\bin\lib\site-packages\win32com\client" folder.
  • You should now be able to run the following sample script which allows you to change the background color by saying the name of the color:
from win32com.client import constants
import win32com.client
import pythoncom
VOICE_COLORS = { "Red" : viz.RED
                ,"Green" : viz.GREEN
                ,"Blue" : viz.BLUE
                ,"Yellow" : viz.YELLOW
                ,"White" : viz.WHITE
                ,"Black" : viz.BLACK
                ,"Purple" : viz.PURPLE
                ,"Orange" : viz.ORANGE }
"""Sample code for using the Microsoft Speech SDK 5.1 via COM in Python.
    Requires that the SDK be installed (it's a free download from
            http://www.microsoft.com/downloads/details.aspx?FamilyId=5E86EC97-40A7-453F-B0EE-6583171B4530&displaylang=en
    and that MakePy has been used on it (in PythonWin,
    select Tools | COM MakePy Utility | Microsoft Speech Object Library 5.1).
    After running this, then saying "One", "Two", "Three" or "Four" should
    display "You said One" etc on the console. The recognition can be a bit
    shaky at first until you've trained it (via the Speech entry in the Windows
    Control Panel."""
class SpeechRecognition:
    """ Initialize the speech recognition with the passed in list of words """
    def __init__(self, wordsToAdd):
        # For speech recognition - first create a listener
        self.listener = win32com.client.Dispatch("SAPI.SpSharedRecognizer")
        # Then a recognition context
        self.context = self.listener.CreateRecoContext()
        # which has an associated grammar
        self.grammar = self.context.CreateGrammar()
        # Do not allow free word recognition - only command and control
        # recognizing the words in the grammar only
        self.grammar.DictationSetState(0)
        # Create a new rule for the grammar, that is top level (so it begins
        # a recognition) and dynamic (ie we can change it at runtime)
        self.wordsRule = self.grammar.Rules.Add("wordsRule", constants.SRATopLevel + constants.SRADynamic, 0)
        # Clear the rule (not necessary first time, but if we're changing it
        # dynamically then it's useful)
        self.wordsRule.Clear()
        # And go through the list of words, adding each to the rule
        [ self.wordsRule.InitialState.AddWordTransition(None, word) for word in wordsToAdd ]
        # Set the wordsRule to be active
        self.grammar.Rules.Commit()
        self.grammar.CmdSetRuleState("wordsRule", 1)
        # Commit the changes to the grammar
        # And add an event handler that's called back when recognition occurs
        self.eventHandler = ContextEvents(self.context)
"""The callback class that handles the events raised by the speech object.
    See "Automation | SpSharedRecoContext (Events)" in the MS Speech SDK
    online help for documentation of the other events supported. """
class ContextEvents(win32com.client.getevents("SAPI.SpSharedRecoContext")):
    """Called when a word/phrase is successfully recognized  -
        ie it is found in a currently open grammar with a sufficiently high
    confidence"""
    def OnRecognition(self, StreamNumber, StreamPosition, RecognitionType, Result):
        newResult = win32com.client.Dispatch(Result)
        print "You said: ",newResult.PhraseInfo.GetText()
        viz.clearcolor(VOICE_COLORS[newResult.PhraseInfo.GetText()])
if __name__=='__main__':
    speechReco = SpeechRecognition(VOICE_COLORS.keys())
    vizact.ontimer(0,pythoncom.PumpWaitingMessages)
    speaker = win32com.client.Dispatch("SAPI.SpVoice")
    speaker.Speak('This script shows how to use the Microsoft Speech SDK with Vizard')
