Using the Eyelink Eye Tracker in Vizard
Filed under: Hardware
Tags:
The Eyelink is an eye tracker made by SR Research. This article describes how to get the Eyelink working with Vizard.
1. Download and install the Eyelink Developer's kit:
https://www.sr-support.com/forums/showthread.php?t=6
To access the support site, you will first need to register at:
2. Download the win32 version of Pylink:
https://www.sr-support.com/forums/showthread.php?t=14.
Included are several Pylink modules for different versions of Python. For Vizard30 use Pylink24.
3. Download the eyelink_viz.zip file and extract the contents. Place the files inside the Pylink24 folder.
4. Run the Popup Calibration utility. The popup calibration program can be found at Start -> Programs->SR Research->EyeLink->Utilities->Popup Calibration.
Before you start the Popup Calibration, set your desired video mode. Then to calibrate, follow the instructions below.
  • Start Popup Calibration.
  • On Popup Calibration select file->New Session 3.
  • Enter a name for the session, and click ok. (The name can be anything, the name will not be used for the recording in the Vizard script)
  • Select Eyelink->Camera Setup.
  • Once the camera setup is done, quit the popup calibration.
5. Run the eyelink_viz.py file. The script includes the following:
  • eyelink initialization
  • event handlers to startRecording, stopRecording, collectSample and closeConnection
The startRecording and stopRecording functions respond to key inputs of 'r' and 's' respectively. The collectSample function is a timer callback function called every 0.05 seconds. While recording, samples are collected from the tracker and a gaze cursor is drawn on the scene. The closeConnection function is an exit handler.
Note: Line 9 takes the size of the drawing window. So, if you are not in full screen mode, gaze values are for the windowed scene.
