NDI Optotrak Motion Capture Device
Filed under: Hardware
Tags:
NDI's Optotrak motion capture system supports both position and orientation data. The video tutorial here will guide you through streaming data from NDI's software to adding the Optotrak plug-in within Vizard and linking the 6DOF sensor data to a viewpoint.
The following example code was used in the video tutorial to connect Vizard's viewpoint to the first Optotrak body
opto = viz.add('optotrak.dle',0,'Dev14')
body = opto.getBody(0)
viz.link(body, viz.MainView)
See Also:
Vizard Manual: NDI Optotrak plug-in
