PPT mocap plug-in
Filed under: Hardware
Tags: , ,
Learn how to use the mocap plug-in to stream data from WorldViz Precision Position Tracker (PPT) to Autodesk MotionBuilder. With this workflow, you can capture an actor's full body motion with just 5 or 6 PPT markers. MotionBuilder is used to apply inverse-kinematics (reconstructing the missing joint data). The results of MotionBuilder can then be streamed again to Vizard for use with Live Characters or for recording to file to later replaying animations.
The key-points covered in this video are:
  • Correctly configuring PPT & plug-in mocap use
  • Combining Intersense cubes for higher quality mocap
  • Adding MotionBuilder output plug-in
  • Correctly reseting T-pose
Related to this tutorial are:
